Salta al contenuto principale
Novatel MiFi 2 4G LTE Hotspot SD Card Replacement
  1. Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement, SD Card: passo 1, immagine 1 di 2 Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement, SD Card: passo 1, immagine 2 di 2
    • Unplug the charger from your Novatel Hotspot device.
    • Place the Novatel Hotspot device face down on a flat, clean surface.
    • Locate the rubber SD Card cover on the bottom left hand side of the device. The cover is labeled “Micro SD.”
  2. Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement: passo 2, immagine 1 di 1
    • Open the SD Card cover by placing your finger on the top of the rubber cover and pulling it down.
    • Remove the faulty SD card from its slot by sliding it out with your finger.
    • This guide does not feature an actual SD Card.
Conclusione
GerardFoley
Membro da: 10/08/18
351 Reputazione
4 Guide realizzate
Marist, Team S1-G5, Chaterdon Fall 2018 Membro di Marist, Team S1-G5, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 145
