Salta al contenuto principale
Novatel MiFi 2 4G LTE Hotspot Battery Replacement
  1. Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery Cover: passo 1, immagine 1 di 3 Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery Cover: passo 1, immagine 2 di 3 Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery Cover: passo 1, immagine 3 di 3
    • Unplug the charger from your Novatel Hotspot device.
    • Place the Novatel Hotspot device face down on a flat, clean surface.
    • Place your thumb under the latch of the black plastic battery cover as shown.
    • Remove the battery cover. This will require some force.
  2. Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery: passo 2, immagine 1 di 2 Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery: passo 2, immagine 2 di 2
    • Gently place your thumb on the right side of the battery as shown.
    • Remove the battery from its socket by lifting it up and out.
Conclusione
GerardFoley
Membro da: 10/08/18
351 Reputazione
4 Guide realizzate
Marist, Team S1-G5, Chaterdon Fall 2018 Membro di Marist, Team S1-G5, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 628
