Nothing Phone (1) Teardown
Scritto Da: tayola
(e un altro collaboratore)
Pubblicato: January 1, 2023
- Commenti: 4
- Preferiti: 0
- Visualizzazioni: 7,5k
Scritto Da: tayola
- Commenti: 4
- Preferiti: 0
Smontaggio
Istruzioni Video
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Nothing Phone (1), usa il nostro manuale di assistenza.
Incorpora questa guida
Scegli una dimensione e copia il codice qui sotto per incorporare questa guida come un piccolo widget sul tuo sito/forum.
4Commenti sulla guida
Does anybody have experience sourcing a replacement microphone for the nothing(1) in the EU?
Daniel - Replica Condividi
Here is a link I found online. I could only find one, but hope this helps:
https://www.maxbhi.com/microphone-for-no...
Also if you are looking for other parts for the nothing 1 click here
https://www.maxbhi.com/nothing-phone-1-s...
If u want it repaired by nothing professionaly, here is the link:
https://us.nothing.tech/pages/support-af...
Diagnostic and repair video, hope this helps!
https://www.youtube.com/watch?v=1gAOoZdc...
tayola - Condividi
I used a passive headphone adapter unknowingly, the phone is now stuck in USB OTG mode and thus Fastboot can't be detected on any computer (Windows, Linux, MacOS) not even lsusb shows anything.
Does anyone know what IC is responsible for switching or has a guide on how to fix this?
Another Ladess - Replica Condividi
Never mind, I found out the solution that worked in my case.
Turns out, plugging in passive headphone adapters may cause the USB mux to become "stuck" (Latch-up?) with in my case 100% success.
In case someone else has an issue of dodgy USB-C stuff, they maybe lucky if it's not fried, the can try:
Keep holding the power button until the phone has rebooted at least 5 times, hopefully that'd clear the fault.
Failing that, I did find the following video that contains a partial reverse-engineer of the USB data path where various chips have readable text atop them:
https://www.youtube.com/watch?v=fyZiOE3H...
Hopes this helps someone fix a similar issue.
Another Ladess - Condividi
