Salta al contenuto principale
Nostalgia GCM200 Power Cable Replacement
Cosa ti serve
  1. Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: passo 1, immagine 1 di 2 Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: passo 1, immagine 2 di 2
    • Remove the two 1.3 mm Phillips #2 screws.
    • Remove the S6 spanner screw.
    • Carefully place these three screws somewhere safe to use later in reassembly.
  2. Nostalgia GCM200 Power Cable Replacement: passo 2, immagine 1 di 1
    • Split the device in half to expose the internal parts of the device.
    • Again, there are two more Phillips screws to remove.
  3. Nostalgia GCM200 Power Cable Replacement: passo 3, immagine 1 di 1
    • Remove the two screws from both sides of the heating coil.
  4. Nostalgia GCM200 Power Cable Replacement, Power Cable: passo 4, immagine 1 di 1
    • Remove (flexible) plastic sleeves from the inside end of the power cable.
    • You might want to use force, pull out while shaking it.
Conclusione
Praful Busa
Membro da: 06/25/17
267 Reputazione
2 Guide realizzate
UW Tacoma, Team S1-G4, Liner Summer 2017 Membro di UW Tacoma, Team S1-G4, Liner Summer 2017
UWT-LINER-SU17S1G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 263
