Salta al contenuto principale
Nostalgia GCM200 Power Button Replacement
Cosa ti serve
  1. Nostalgia GCM200 Power Button Replacement, Nostalgia GCM200 Disassembly: passo 1, immagine 1 di 2 Nostalgia GCM200 Power Button Replacement, Nostalgia GCM200 Disassembly: passo 1, immagine 2 di 2
    • Remove the two 1.3 mm Phillips #2 screws.
    • Remove the S6 spanner screw.
    • Carefully place these three screws somewhere safe to use later in reassembly.
  2. Nostalgia GCM200 Power Button Replacement: passo 2, immagine 1 di 1
    • Split the device in half to expose the internal parts of the device.
    • Again, there are two more Phillips screws to remove.
  3. Nostalgia GCM200 Power Button Replacement: passo 3, immagine 1 di 1
    • Remove the two screws from both sides of the heating coil.
  4. Nostalgia GCM200 Power Button Replacement, Power Button: passo 4, immagine 1 di 1
    • Split the device into 2 parts to change the power button.
    • Power button hold the other parts, so be careful.
  5. Nostalgia GCM200 Power Button Replacement: passo 5, immagine 1 di 1
    • Remove (flexible) plastic sleeves from the inside end of the power cable.
    • You might want to use force, pull out while shaking it.
    • Inside the product, ensure you look at the power button and try to understand this step before you take action. There are two notches, push them at the same time on both sides to push the button out of the device.
  6. Nostalgia GCM200 Power Button Replacement: passo 6, immagine 1 di 1
    • Depress the little tab inside the top portion of the device to remove the On/Off switch.
  7. Nostalgia GCM200 Power Button Replacement: passo 7, immagine 1 di 1
    • Replace the power button, and put the plastic sleeves in the original position.
    • Great, you just finished replacing power button
  8. Nostalgia GCM200 Power Button Replacement: passo 8, immagine 1 di 1
    • To reassemble your device, follow these instructions in reverse order.
Conclusione
This guide will help you to replace the power button
Altre 3 persone hanno completato questa guida.
Xingdi Zhou
Membro da: 06/27/17
466 Reputazione
3 Guide realizzate
UW Tacoma, Team S1-G4, Liner Summer 2017 Membro di UW Tacoma, Team S1-G4, Liner Summer 2017
UWT-LINER-SU17S1G4
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 282
