Salta al contenuto principale
Nostalgia Electrics RHP-310 Housing Replacement
Cosa ti serve
  1. Nostalgia Electrics RHP-310 Housing Replacement, Power Switch: passo 1, immagine 1 di 1
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Housing Replacement: passo 2, immagine 1 di 1
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Housing Replacement: passo 3, immagine 1 di 1
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Housing Replacement: passo 4, immagine 1 di 2 Nostalgia Electrics RHP-310 Housing Replacement: passo 4, immagine 2 di 2
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Housing Replacement: passo 5, immagine 1 di 1
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Housing Replacement: passo 6, immagine 1 di 1
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
  7. Nostalgia Electrics RHP-310 Housing Replacement, Housing: passo 7, immagine 1 di 2 Nostalgia Electrics RHP-310 Housing Replacement, Housing: passo 7, immagine 2 di 2
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
    • Save the screws from this step. You will need them to connect the new housing to the white top.
  8. Nostalgia Electrics RHP-310 Housing Replacement: passo 8, immagine 1 di 1
    • Remove the white top from the housing.
Conclusione
Dana Clarke
Membro da: 09/26/12
50 Reputazione
6 Guide realizzate
Cal Poly, Team 16-57, Forte Fall 2012 Membro di Cal Poly, Team 16-57, Forte Fall 2012
CPSU-FORTE-F12S16G57
5 Membri
6 Guide realizzate
Un commento
Hello thank you very much. I need the electrinonic circuit because one component it's broken . Hoy can i get it. Thank you very Much!
cris nav - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 541
