Salta al contenuto principale
Nostalgia Electrics PCM805 Stand Replacement
Cosa ti serve
  1. Nostalgia Electrics PCM805 Stand Replacement, Unscrewing the base: passo 1, immagine 1 di 2 Nostalgia Electrics PCM805 Stand Replacement, Unscrewing the base: passo 1, immagine 2 di 2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Stand Replacement: passo 2, immagine 1 di 1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Stand Replacement, Stand: passo 3, immagine 1 di 1
    • Locate the four 10mm Phillips #02 screws on the inside of the panel.
  4. Nostalgia Electrics PCM805 Stand Replacement: passo 4, immagine 1 di 3 Nostalgia Electrics PCM805 Stand Replacement: passo 4, immagine 2 di 3 Nostalgia Electrics PCM805 Stand Replacement: passo 4, immagine 3 di 3
    • Remove the screw of the foot you plan to replace.
    • Place your finger on the back of the the foot you are unscrewing for support.
Conclusione
Carlton
Membro da: 01/13/15
672 Reputazione
5 Guide realizzate
USF Tampa, Team 3-5, Hickman Winter 2015 Membro di USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 412
