Salta al contenuto principale
Nostalgia Electrics PCM805 Power Switch Replacement
Cosa ti serve
  1. Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: passo 1, immagine 1 di 2 Nostalgia Electrics PCM805 Power Switch Replacement, Unscrewing the base: passo 1, immagine 2 di 2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Power Switch Replacement: passo 2, immagine 1 di 1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Power Switch Replacement, Power Switch: passo 3, immagine 1 di 1
    • Locate the switch/wire assembly inside the device.
  4. Nostalgia Electrics PCM805 Power Switch Replacement: passo 4, immagine 1 di 1
    • Pull back the insulation sleeves to expose the connector heads.
  5. Nostalgia Electrics PCM805 Power Switch Replacement: passo 5, immagine 1 di 2 Nostalgia Electrics PCM805 Power Switch Replacement: passo 5, immagine 2 di 2
    • Note the color of each wire and the order you remove them.
    • Using a pair of pliers, firmly grip the base of the wire.
    • Be sure to grip where the connector meets the wire and not where the connector covers the switch prong.
    • Pull the wire straight out of the switch.
    • Repeat this step for each wire.
  6. Nostalgia Electrics PCM805 Power Switch Replacement: passo 6, immagine 1 di 2 Nostalgia Electrics PCM805 Power Switch Replacement: passo 6, immagine 2 di 2
    • Using pliers, pinch tabs at the top and bottom of switch.
    • While pinching the tabs, push the switch until the tabs are on the outside of the device.
  7. Nostalgia Electrics PCM805 Power Switch Replacement: passo 7, immagine 1 di 2 Nostalgia Electrics PCM805 Power Switch Replacement: passo 7, immagine 2 di 2
    • Remove the switch from the device.
Conclusione
Carlton
Membro da: 01/13/15
672 Reputazione
5 Guide realizzate
USF Tampa, Team 3-5, Hickman Winter 2015 Membro di USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Membri
8 Guide realizzate
1Commento della guida
The red light turns on but the disk isnt spinning or heating up and when the out let has power
Manuela Velez - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,127
