Salta al contenuto principale
Nostalgia Electrics PCM805 Motor Replacement
Cosa ti serve
  1. Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: passo 1, immagine 1 di 2 Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: passo 1, immagine 2 di 2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Motor Replacement: passo 2, immagine 1 di 1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: passo 3, immagine 1 di 2 Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: passo 3, immagine 2 di 2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  4. Nostalgia Electrics PCM805 Motor Replacement: passo 4, immagine 1 di 3 Nostalgia Electrics PCM805 Motor Replacement: passo 4, immagine 2 di 3 Nostalgia Electrics PCM805 Motor Replacement: passo 4, immagine 3 di 3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  5. Nostalgia Electrics PCM805 Motor Replacement, Motor: passo 5, immagine 1 di 2 Nostalgia Electrics PCM805 Motor Replacement, Motor: passo 5, immagine 2 di 2
    • Remove the four 12mm Phillips #02 screws to free the motor housing.
  6. Nostalgia Electrics PCM805 Motor Replacement: passo 6, immagine 1 di 2 Nostalgia Electrics PCM805 Motor Replacement: passo 6, immagine 2 di 2
    • Line up the prongs on the motor shaft with the holes in the heating element and pull the motor out.
Conclusione
USF Tampa, Team 3-5, Hickman Winter 2015 Membro di USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Membri
8 Guide realizzate
2 Commenti
Hello.
I purchased this item in a red variation from VAT19. It does not work but the light comes on. I live in the UK and we have a higher Voltage(240V) running in our domestic supply.
Something may have blown.
Can you advise what is it likely to be?
If there is a part that we can replace, can you advise which one and where I can purchase it from please?
Moh - Replica
Hi, I need the cotton machine from the nostalgia cotton sugar machine and I don't know where to get it. can you help me? My email is terebcn18@hotmail.com
Teresa gb - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 58
Tutti i Tempi: 3,124
