Salta al contenuto principale
Introduzione
If you can't hear the other line, then your speaker is broken. Use this guide in order to replace the damaged speakerphone speaker.
  1. Flip the phone over to view the back. Remove the power and phone cords. Remove the power and phone cords.
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Remove the seven 8mm Phillips #2 screws.
    • Remove the seven 8mm Phillips #2 screws.
  3. Lift up the back cover slowly because there are still wires attached to the circuit board. Lifting the back cover should not require a lot of force; simply lift with your fingertips.
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
  5. Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  6. Remove the six 8mm Phillips #2 screws. Pull the speaker phone cover straight up.
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  7. Lift the speaker straight up.
    • Lift the speaker straight up.
    • The speaker may need to be slightly wiggled in order to loosen and remove.
  8. Cut the red and white wires as close to the speaker as possible.
    • Cut the red and white wires as close to the speaker as possible.
    • Wire cutters are preferred, but normal scissors are fine too.
  9. Solder wires to new speaker. Solder wires to new speaker.
    • Solder wires to new speaker.
Conclusione
Elizabeth
Membro da: 21/01/2012
160 Reputazione
3 Guide realizzate
Cal Poly, Team 10-35, Amido Winter 2012 Membro di Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 980
