Salta al contenuto principale
Nortel Networks i2004 IP Circuit Board Replacement
Cosa ti serve
  1. Nortel Networks i2004 IP Circuit Board Replacement, Back Cover: passo 1, immagine 1 di 3 Nortel Networks i2004 IP Circuit Board Replacement, Back Cover: passo 1, immagine 2 di 3 Nortel Networks i2004 IP Circuit Board Replacement, Back Cover: passo 1, immagine 3 di 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Circuit Board Replacement: passo 2, immagine 1 di 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Circuit Board Replacement: passo 3, immagine 1 di 2 Nortel Networks i2004 IP Circuit Board Replacement: passo 3, immagine 2 di 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Circuit Board Replacement: passo 4, immagine 1 di 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Circuit Board Replacement: passo 5, immagine 1 di 2 Nortel Networks i2004 IP Circuit Board Replacement: passo 5, immagine 2 di 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Circuit Board Replacement, Circuit Board: passo 6, immagine 1 di 1
    • Remove the red and white wires from the rubber casing rim.
  7. Nortel Networks i2004 IP Circuit Board Replacement: passo 7, immagine 1 di 2 Nortel Networks i2004 IP Circuit Board Replacement: passo 7, immagine 2 di 2
    • Lift out the speaker and set it away from the tray that holds it.
    • Then remove the black plastic tray at the bottom by lifting it straight up.
  8. Nortel Networks i2004 IP Circuit Board Replacement: passo 8, immagine 1 di 1
    • Remove the two 8mm Phillips #2 screws.
  9. Nortel Networks i2004 IP Circuit Board Replacement: passo 9, immagine 1 di 2 Nortel Networks i2004 IP Circuit Board Replacement: passo 9, immagine 2 di 2
    • Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
  10. Nortel Networks i2004 IP Circuit Board Replacement: passo 10, immagine 1 di 3 Nortel Networks i2004 IP Circuit Board Replacement: passo 10, immagine 2 di 3 Nortel Networks i2004 IP Circuit Board Replacement: passo 10, immagine 3 di 3
    • There are three clips on the circuit board to un-clip.
    • Unclip both back black clips with your fingertips.
    • Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
  11. Nortel Networks i2004 IP Circuit Board Replacement: passo 11, immagine 1 di 2 Nortel Networks i2004 IP Circuit Board Replacement: passo 11, immagine 2 di 2
    • There's a brown ribbon still attached to the circuit board and phone case, so don't pull the circuit board completely off just yet.
    • Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
  12. Nortel Networks i2004 IP Circuit Board Replacement: passo 12, immagine 1 di 1
    • Push down each brown clip on either side of the brown metal strip using your fingertip.
    • Detach the circuit board from the brown ribbon.
  13. Nortel Networks i2004 IP Circuit Board Replacement: passo 13, immagine 1 di 1
    • Remove the clear rubber casing.
    • Be careful not to flip over the front phone casing or all of the buttons will fall out.
Conclusione
Altre 2 persone hanno completato questa guida.
Elizabeth
Membro da: 01/21/12
175 Reputazione
3 Guide realizzate
Cal Poly, Team 10-35, Amido Winter 2012 Membro di Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,342
