Salta al contenuto principale
Introduzione
Use this guide to replace the screen bezel of the Nook Tablet. Removing this plastic frame is a prerequisite for accessing most of the Nook's internal components.
Parti
Nessuna parte specificata.
  1. Remove the ten T5 screws from around the edges of the silver midframe. Remove the ten T5 screws from around the edges of the silver midframe.
    • Remove the ten T5 screws from around the edges of the silver midframe.
  2. Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe. Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
Conclusione
Jacob Metzinger
Membro da: 25/09/2012
80 Reputazione
2 Guide realizzate
Cal Poly, Team 1-4, Propen Fall 2012 Membro di Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 623
