Salta al contenuto principale
Nook Tablet Display Replacement
Cosa ti serve
  1. Nook Tablet Display Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the Nook over.
  2. Nook Tablet Display Replacement: passo 2, immagine 1 di 2 Nook Tablet Display Replacement: passo 2, immagine 2 di 2
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
  3. Nook Tablet Display Replacement: passo 3, immagine 1 di 2 Nook Tablet Display Replacement: passo 3, immagine 2 di 2
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Display Replacement: passo 4, immagine 1 di 2 Nook Tablet Display Replacement: passo 4, immagine 2 di 2
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Display Replacement: passo 5, immagine 1 di 1
    • Pull the back panel off the Nook.
  6. Nook Tablet Display Replacement, Screen Bezel: passo 6, immagine 1 di 2 Nook Tablet Display Replacement, Screen Bezel: passo 6, immagine 2 di 2
    • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
  7. Nook Tablet Display Replacement: passo 7, immagine 1 di 2 Nook Tablet Display Replacement: passo 7, immagine 2 di 2
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  8. Nook Tablet Display Replacement, Disconnect the Battery: passo 8, immagine 1 di 2 Nook Tablet Display Replacement, Disconnect the Battery: passo 8, immagine 2 di 2
    • Lift up the foam pad at the corner of the battery to reveal the battery connector.
    • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
  9. Nook Tablet Display Replacement, Midframe: passo 9, immagine 1 di 1
    • Lift up the foam that covers the power connector and volume connector.
    • Disconnect the power and volume cables from their sockets on the motherboard.
  10. Nook Tablet Display Replacement: passo 10, immagine 1 di 2 Nook Tablet Display Replacement: passo 10, immagine 2 di 2
    • Carefully lift the silver midframe away from the motherboard and display assembly.
    • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
  11. Nook Tablet Display Replacement, Display: passo 11, immagine 1 di 2 Nook Tablet Display Replacement, Display: passo 11, immagine 2 di 2
    • Orient the mother board as shown, so that the screen is facing downwards.
    • Grab the corner of the orange strip on the right side of the mother board as shown.
    • The orange strip is adhered to the mother board, gently lift the strip so that the adhesion is broken.
    • The strip will still be attached by the circuit connection to the mother board, proceed to the next step.
  12. Nook Tablet Display Replacement: passo 12, immagine 1 di 3 Nook Tablet Display Replacement: passo 12, immagine 2 di 3 Nook Tablet Display Replacement: passo 12, immagine 3 di 3
    • The orange strip will still be attached at this point
    • Insert the end of a flat head screw driver between the connection of the strip and mother board and pry upward.
    • Grab the strip and gently pull upward to finish the disconnection.
  13. Nook Tablet Display Replacement: passo 13, immagine 1 di 2 Nook Tablet Display Replacement: passo 13, immagine 2 di 2
    • On the left side of the motherboard, you will see another orange strip, this one is taped down to the motherboard.
    • Remove the tape.
  14. Nook Tablet Display Replacement: passo 14, immagine 1 di 3 Nook Tablet Display Replacement: passo 14, immagine 2 di 3 Nook Tablet Display Replacement: passo 14, immagine 3 di 3
    • After the tape has been removed, the strip will still be attached to the motherboard by the hinge pictured here.
    • Slide the tip of a flat head screwdriver under the hinge and pry the hinge upward.
    • The orange strip should now be detached from the mother board.
  15. Nook Tablet Display Replacement: passo 15, immagine 1 di 3 Nook Tablet Display Replacement: passo 15, immagine 2 di 3 Nook Tablet Display Replacement: passo 15, immagine 3 di 3
    • The screen is adhered to the mother board at the screw holes marked
    • Break the adhesion by inserting the edge of a flat head screwdriver inbetween the motherboard and the pieces of the screen at the marked holes
    • Lift the screen from the display.
Conclusione
Altre 12 persone hanno completato questa guida.
Cal Poly, Team 1-4, Propen Fall 2012 Membro di Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Membri
14 Guide realizzate
2Commenti sulla guida
Where can one get a replacement screen for the glow-light first model?
Hank - Replica
I need battery
Mister A - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 17
Tutti i Tempi: 32,654
