Introduzione
Steps to replace a broken speaker in the Nook HD+ tablet.
Cosa ti serve
Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
Pry open the front frame.
Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
Carefully remove the bottom frame from center chassis.
Detach the battery ribbon from the motherboard.
Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
In the bottom left hand corner remove the 3 screws that at attached to the speaker
Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
Replace old speaker with new speaker then follow instructions in reverse order to reassemble
Altre 2 persone hanno completato questa guida.
Un commento
After purchasing a replacement speaker, these steps worked well. Process to a fairly relaxed 20 minutes.
The only thing I’d add is that the speaker is part # AAC121217U22A, and appears to be a bespoke part containing two speakers.
Knowing what part to look for may help others looking for a replacement part.
