Salta al contenuto principale
Nook HD+ Motherboard Replacement
Cosa ti serve
  1. Nook HD+ Motherboard Replacement, Motherboard: passo 1, immagine 1 di 3 Nook HD+ Motherboard Replacement, Motherboard: passo 1, immagine 2 di 3 Nook HD+ Motherboard Replacement, Motherboard: passo 1, immagine 3 di 3
    • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
    • Pop up all plastic tabs that secure the frame to the chassis.
  2. Nook HD+ Motherboard Replacement: passo 2, immagine 1 di 3 Nook HD+ Motherboard Replacement: passo 2, immagine 2 di 3 Nook HD+ Motherboard Replacement: passo 2, immagine 3 di 3
    • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
    • Disconnect battery from motherboard.
    • Remove back casing.
  3. Nook HD+ Motherboard Replacement: passo 3, immagine 1 di 2 Nook HD+ Motherboard Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
    • Use tweezers to lift the flaps.
  4. Nook HD+ Motherboard Replacement: passo 4, immagine 1 di 1
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
    • No tool is needed. Gently pull on the wires until the piece disconnects.
  5. Nook HD+ Motherboard Replacement: passo 5, immagine 1 di 1
    • Disconnect antenna from motherboard by pulling up with slight force.
  6. Nook HD+ Motherboard Replacement: passo 6, immagine 1 di 2 Nook HD+ Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
    • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
  7. Nook HD+ Motherboard Replacement: passo 7, immagine 1 di 2 Nook HD+ Motherboard Replacement: passo 7, immagine 2 di 2
    • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
    • Remove the motherboard.
Conclusione
IUPUI, Team 3-3, Harley Spring 2022 Membro di IUPUI, Team 3-3, Harley Spring 2022
IUPUI-HARLEY-S22S3G3
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 255
