Salta al contenuto principale
Nook HD+ Antenna Replacement
Cosa ti serve
  1. Nook HD+ Antenna Replacement, Antenna: passo 1, immagine 1 di 1
    • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
  2. Nook HD+ Antenna Replacement, Remove the screws: passo 2, immagine 1 di 2 Nook HD+ Antenna Replacement, Remove the screws: passo 2, immagine 2 di 2
    • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Antenna Replacement, Remove the chassis: passo 3, immagine 1 di 2 Nook HD+ Antenna Replacement, Remove the chassis: passo 3, immagine 2 di 2
    • Carefully remove the center chassis from the bottom frame.
  4. Nook HD+ Antenna Replacement, Dettatch battery: passo 4, immagine 1 di 3 Nook HD+ Antenna Replacement, Dettatch battery: passo 4, immagine 2 di 3 Nook HD+ Antenna Replacement, Dettatch battery: passo 4, immagine 3 di 3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Antenna Replacement, Flip the center chassis: passo 5, immagine 1 di 1
    • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
  6. Nook HD+ Antenna Replacement, Remove the antenna part 1: passo 6, immagine 1 di 2 Nook HD+ Antenna Replacement, Remove the antenna part 1: passo 6, immagine 2 di 2
    • Remove the wire from the attachment on the motherboard (this wire un-clips).
  7. Nook HD+ Antenna Replacement, Remove the antenna part 2: passo 7, immagine 1 di 2 Nook HD+ Antenna Replacement, Remove the antenna part 2: passo 7, immagine 2 di 2
    • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
  8. Nook HD+ Antenna Replacement, Place new antenna.: passo 8, immagine 1 di 2 Nook HD+ Antenna Replacement, Place new antenna.: passo 8, immagine 2 di 2
    • Replace new antenna following all the steps in reverse.
Conclusione
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Membro di UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,128
