Introduzione
This guide tells you how to replace the battery on the Nook HD+ from Barnes & Noble.
Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
Aggiungi Commento
Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
Aggiungi Commento
  • Carefully remove center chassis from bottom frame.
Aggiungi Commento
  • Detach the battery ribbon from the motherboard.
Aggiungi Commento
  • Pry battery off of bottom frame using plastic opening tool.
Aggiungi Commento
  • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
Aggiungi Commento
Conclusione
Altre 8 persone hanno completato questa guida.
Elijah Gonsalves
Membro da: 24/10/2014
905 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Membro di UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Membri
5 Guide realizzate
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - Replica
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - Replica
Anyone have a lead on good batteries?
omarhani - Replica
clear directions, liked this guide
wandat100 - Replica
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 107
Tutti i Tempi: 5,381
