Introduzione
This replacement guide for the Nook HD+ requires the use of a soldering iron which should not be used by children, and if mishandled could lead to extreme injury.
Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
  • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
Aggiungi Commento
Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
Aggiungi Commento
  • Carefully remove the center chassis from the bottom frame.
Aggiungi Commento
  • Detach the battery ribbon from the motherboard.
Aggiungi Commento
  • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
Aggiungi Commento
  • Remove the wire from the attachment on the motherboard (this wire un-clips).
Aggiungi Commento
  • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
Aggiungi Commento
  • Replace new antenna following all the steps in reverse.
Aggiungi Commento
Conclusione
Elijah Gonsalves
Membro da: 24/10/2014
905 Reputazione
3 Guide realizzate
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Membro di UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 693
