Salta al contenuto principale
Nook Color Motherboard Replacement
Cosa ti serve
  1. Nook Color Motherboard Replacement, Back Cover: passo 1, immagine 1 di 2 Nook Color Motherboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
  2. Nook Color Motherboard Replacement: passo 2, immagine 1 di 2 Nook Color Motherboard Replacement: passo 2, immagine 2 di 2
    • Pry off the back cover with the plastic opening tool. Go around the device with the tool to ensure complete detachment.
  3. Nook Color Motherboard Replacement, Front Cover: passo 3, immagine 1 di 1
    • Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
  4. Nook Color Motherboard Replacement: passo 4, immagine 1 di 2 Nook Color Motherboard Replacement: passo 4, immagine 2 di 2
    • Pry off the front panel using the plastic opening tool.
  5. Nook Color Motherboard Replacement: passo 5, immagine 1 di 2 Nook Color Motherboard Replacement: passo 5, immagine 2 di 2
    • Lift up on the connectors to disconnect them using the plastic opening tool.
  6. Nook Color Motherboard Replacement, Motherboard: passo 6, immagine 1 di 3 Nook Color Motherboard Replacement, Motherboard: passo 6, immagine 2 di 3 Nook Color Motherboard Replacement, Motherboard: passo 6, immagine 3 di 3
    • Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
  7. Nook Color Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the easy-to-miss T5 Torx 3.8 mm screw located in the tabbed corner of the device.
  8. Nook Color Motherboard Replacement: passo 8, immagine 1 di 2 Nook Color Motherboard Replacement: passo 8, immagine 2 di 2
    • Lift the motherboard gently from the side with the larger connector ribbon.
    • Slide the white cable gently from underneath its holding place to free the motherboard completely.
    • Remove the motherboard carefully from the device.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 11-5, Blackwell Winter 2015 Membro di USF Tampa, Team 11-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G5
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,156
