Introduzione
Is your Nokia X unable to connect to a USB charger? This guide will shows how to replace a faulty USB port.
Cosa ti serve
Remove the back cover of the device by applying light pressure toward the outer rim and display.
Again, using a spudger tool, release the rear facing camera from the light swap display.
Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
Altre 6 persone hanno completato questa guida.
