Salta al contenuto principale
Nokia N900 USB Replacement
Cosa ti serve
  1. Nokia N900 USB Replacement, USB: passo 1, immagine 1 di 1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 USB Replacement: passo 2, immagine 1 di 2 Nokia N900 USB Replacement: passo 2, immagine 2 di 2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 USB Replacement: passo 3, immagine 1 di 1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 USB Replacement: passo 4, immagine 1 di 2 Nokia N900 USB Replacement: passo 4, immagine 2 di 2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 USB Replacement: passo 5, immagine 1 di 1
    • You will now have two halves of the phone.
    • Grab the half of the phone that has the keyboard on it
  6. Nokia N900 USB Replacement: passo 6, immagine 1 di 1
    • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
    • Place the key pad and cover to the side for the remaining steps.
  7. Nokia N900 USB Replacement: passo 7, immagine 1 di 1
    • Use a blue plastic opening tool lift the motherboard out of the back cover
  8. Nokia N900 USB Replacement: passo 8, immagine 1 di 1
    • Look at the bottom of the motherboard to find the:
    • USB Port
    • Once you've located the USB Port you can search online or call the manufacturer to replace it.
Conclusione
Altre 3 persone hanno completato questa guida.
Troy Posey
Membro da: 03/13/14
349 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 2,691
