Salta al contenuto principale
Nokia N70 Keypad Replacement
Cosa ti serve
  1. Nokia N70 Keypad Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Keypad Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Keypad Replacement: passo 3, immagine 1 di 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Keypad Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the phone.
  5. Nokia N70 Keypad Replacement, Keypad: passo 5, immagine 1 di 3 Nokia N70 Keypad Replacement, Keypad: passo 5, immagine 2 di 3 Nokia N70 Keypad Replacement, Keypad: passo 5, immagine 3 di 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Keypad Replacement: passo 6, immagine 1 di 3 Nokia N70 Keypad Replacement: passo 6, immagine 2 di 3 Nokia N70 Keypad Replacement: passo 6, immagine 3 di 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
Conclusione
Justin
Membro da: 10/12/11
984 Reputazione
5 Guide realizzate
Cal Poly, Team 6-2, Regan Fall 2011 Membro di Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Membri
10 Guide realizzate
Un commento
I have N70 nokia mobile. Its keypad buttons 1, 2 & C and also left key and upper key is not working
please give me solution how to solve this problem
Imamuddin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,992
