Salta al contenuto principale
Nokia N70 Display Replacement
Cosa ti serve
  1. Nokia N70 Display Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Display Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Display Replacement: passo 3, immagine 1 di 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Display Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the phone.
  5. Nokia N70 Display Replacement, Keypad: passo 5, immagine 1 di 3 Nokia N70 Display Replacement, Keypad: passo 5, immagine 2 di 3 Nokia N70 Display Replacement, Keypad: passo 5, immagine 3 di 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Display Replacement: passo 6, immagine 1 di 3 Nokia N70 Display Replacement: passo 6, immagine 2 di 3 Nokia N70 Display Replacement: passo 6, immagine 3 di 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Display Replacement, Display: passo 7, immagine 1 di 1
    • Using a torx T6 screwdriver remove the six 15 mm torx screws.
  8. Nokia N70 Display Replacement: passo 8, immagine 1 di 2 Nokia N70 Display Replacement: passo 8, immagine 2 di 2
    • Separate the front panel of the phone by pulling the bottom of the panel at a 45 degree angle.
  9. Nokia N70 Display Replacement: passo 9, immagine 1 di 2 Nokia N70 Display Replacement: passo 9, immagine 2 di 2
    • Lift the bottom of the display circuit board up and locate the ribbon connection located where the two circuit boards intersect.
    • Remove the ribbon connection that connects the two circuit boards.
  10. Nokia N70 Display Replacement: passo 10, immagine 1 di 3 Nokia N70 Display Replacement: passo 10, immagine 2 di 3 Nokia N70 Display Replacement: passo 10, immagine 3 di 3
    • While pulling back each of the clamps marked in the image, lift out each side of the screen independently.
    • Be careful when using the plastic prying tool to not scratch the display.
Conclusione
Altre 8 persone hanno completato questa guida.
Justin
Membro da: 10/12/11
1.026 Reputazione
5 Guide realizzate
Cal Poly, Team 6-2, Regan Fall 2011 Membro di Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Membri
11 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 32
Tutti i Tempi: 9,111
