Salta al contenuto principale
Nokia N70 Back Camera Replacement
Cosa ti serve
  1. Nokia N70 Back Camera Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Back Camera Replacement: passo 2, immagine 1 di 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Back Camera Replacement: passo 3, immagine 1 di 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Back Camera Replacement: passo 4, immagine 1 di 1
    • Remove the battery from the phone.
  5. Nokia N70 Back Camera Replacement, Keypad: passo 5, immagine 1 di 3 Nokia N70 Back Camera Replacement, Keypad: passo 5, immagine 2 di 3 Nokia N70 Back Camera Replacement, Keypad: passo 5, immagine 3 di 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Back Camera Replacement: passo 6, immagine 1 di 3 Nokia N70 Back Camera Replacement: passo 6, immagine 2 di 3 Nokia N70 Back Camera Replacement: passo 6, immagine 3 di 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Back Camera Replacement, Back Camera: passo 7, immagine 1 di 2 Nokia N70 Back Camera Replacement, Back Camera: passo 7, immagine 2 di 2
    • Using T6 Torx screwdriver remove the six 15 mm torx screws.
  8. Nokia N70 Back Camera Replacement: passo 8, immagine 1 di 3 Nokia N70 Back Camera Replacement: passo 8, immagine 2 di 3 Nokia N70 Back Camera Replacement: passo 8, immagine 3 di 3
    • Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
    • Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
  9. Nokia N70 Back Camera Replacement: passo 9, immagine 1 di 3 Nokia N70 Back Camera Replacement: passo 9, immagine 2 di 3 Nokia N70 Back Camera Replacement: passo 9, immagine 3 di 3
    • Locate the rear circuit board by flipping over the front panel.
    • Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
    • Caution: Be careful when prying camera out of the slot for the connections are fragile.
Conclusione
Altre 5 persone hanno completato questa guida.
Justin
Membro da: 10/12/11
984 Reputazione
5 Guide realizzate
Cal Poly, Team 6-2, Regan Fall 2011 Membro di Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Membri
10 Guide realizzate
Un commento
mon nokia n70 est mal camera alors quest -ce qu*on va faire
sidiahmed ahmed - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 16
Tutti i Tempi: 8,796
