Introduzione
If the display on your Nokia Lumia 930 does not light up, or is severely damaged, use this guide to replace it! Before beginning, make sure to power off your phone completely and disconnect from any external power source.
Pull the SIM card holder out of the top of the phone using your fingernail.
Use the flat end of a spudger to disconnect the camera connectors.
Pull the camera up and out to remove it from the phone.
Use the pointed end of the spudger to pry up the daughterboard.
Use tweezers to lift the daughterboard out of the phone.
Place a suction cup in the center of the screen, then pry the display away from the frame.
