Salta al contenuto principale
Nokia Lumia 925 Front Camera Replacement
Cosa ti serve
  1. Nokia Lumia 925 Front Camera Replacement, Motherboard: passo 1, immagine 1 di 2 Nokia Lumia 925 Front Camera Replacement, Motherboard: passo 1, immagine 2 di 2
    • Remove the sim card holder by inserting tweezers into the hole. Push down and the holder will spring back up.
    • Pull out the holder until it is completely separate.
    • Something like a paperclip will work if there are no tweezers available.
  2. Nokia Lumia 925 Front Camera Replacement: passo 2, immagine 1 di 3 Nokia Lumia 925 Front Camera Replacement: passo 2, immagine 2 di 3 Nokia Lumia 925 Front Camera Replacement: passo 2, immagine 3 di 3
    • Slide a plastic opening tool under the back cover.
    • Slide the tool around the outsides of the cover to fully dislodge the pins holding the cover to the phone.
    • Some pins are facing the opposite way from the others.
  3. Nokia Lumia 925 Front Camera Replacement: passo 3, immagine 1 di 3 Nokia Lumia 925 Front Camera Replacement: passo 3, immagine 2 di 3 Nokia Lumia 925 Front Camera Replacement: passo 3, immagine 3 di 3
    • Remove the 3 screws using the T7 Torx screwdriver.
    • Unclip the black tab connector.
  4. Nokia Lumia 925 Front Camera Replacement: passo 4, immagine 1 di 2 Nokia Lumia 925 Front Camera Replacement: passo 4, immagine 2 di 2
    • Remove the silver metal cover.
    • Be careful of the tape under the right square side of the panel. Using a spudger helps.
  5. Nokia Lumia 925 Front Camera Replacement: passo 5, immagine 1 di 3 Nokia Lumia 925 Front Camera Replacement: passo 5, immagine 2 di 3 Nokia Lumia 925 Front Camera Replacement: passo 5, immagine 3 di 3
    • Unclip the two orange tabs.
    • Remove the four silver screws using the T5 Torx screwdriver.
  6. Nokia Lumia 925 Front Camera Replacement: passo 6, immagine 1 di 2 Nokia Lumia 925 Front Camera Replacement: passo 6, immagine 2 di 2
    • Remove the motherboard by sliding tweezers between it and the back of the screen. Lift up.
  7. Nokia Lumia 925 Front Camera Replacement, Display: passo 7, immagine 1 di 2 Nokia Lumia 925 Front Camera Replacement, Display: passo 7, immagine 2 di 2
    • Push the screen from the inside of the phone.
    • Pull the screen off.
    • Slide the electronic strip through the small opening.
  8. Nokia Lumia 925 Front Camera Replacement, Speaker: passo 8, immagine 1 di 1
    • Locate the grey speaker/camera cover.
    • Carefully remove the cover with either a pair of tweezers or your fingers.
  9. Nokia Lumia 925 Front Camera Replacement: passo 9, immagine 1 di 3 Nokia Lumia 925 Front Camera Replacement: passo 9, immagine 2 di 3 Nokia Lumia 925 Front Camera Replacement: passo 9, immagine 3 di 3
    • With a pair of tweezers, gently remove the orange colored tab closest to the speaker.
  10. Nokia Lumia 925 Front Camera Replacement, Front Camera: passo 10, immagine 1 di 1
    • Pull at the orange section until it becomes loose.
    • It is located in the upper leftmost section of the phone behind the front camera.
  11. Nokia Lumia 925 Front Camera Replacement: passo 11, immagine 1 di 1
    • Pull vertically on the same orange section until the front camera comes out.
    • The front camera as well as the speaker may come out after the last step so be careful.
Conclusione
O'Ryan Lacour
Membro da: 09/18/18
85 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 191
