Salta al contenuto principale
Nokia Lumia 900 Screen Replacement
Cosa ti serve
  1. Nokia Lumia 900 Screen Replacement, Opening The Phone: passo 1, immagine 1 di 2 Nokia Lumia 900 Screen Replacement, Opening The Phone: passo 1, immagine 2 di 2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Screen Replacement, Detaching Screen Connectors: passo 2, immagine 1 di 1
    • Detach both ribbon connectors from the logic board.
    • Attach new screen connectors to logic board
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
Conclusione
Altre 3 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,999
