Cosa ti serve
Passo 1 Opening The Phone
Attenzione: il passaggio 1 proviene da una guida contrassegnata come in corso.
Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
Using the opening tool, pry the screen from the casing until they are separated from each other.
Attach new screen connectors to logic board
Slide the hinges of the left side of the screen under the left side of the plastic case
Clamp the right side of the screen down and make sure screen is flat
The screen should "click" into place
Altre 3 persone hanno completato questa guida.
