Salta al contenuto principale
Nokia Lumia 900 Front Camera Replacement
Cosa ti serve
  1. Nokia Lumia 900 Front Camera Replacement, Opening The Phone: passo 1, immagine 1 di 2 Nokia Lumia 900 Front Camera Replacement, Opening The Phone: passo 1, immagine 2 di 2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Front Camera Replacement, Detach Ribbon: passo 2, immagine 1 di 1
    • Detach camera ribbon from motherboard
  3. Nokia Lumia 900 Front Camera Replacement, Remove Camera: passo 3, immagine 1 di 1
    • Peel camera off of adhesive surface
    • Use caution when removing camera as it is fragile
  4. Nokia Lumia 900 Front Camera Replacement, Installing New Camera: passo 4, immagine 1 di 1
    • Apply adhesive to back of camera
    • Attach ribbon to motherboard
    • Press down on camera for 60 seconds
    • Let dry for 5 minutes
  5. Nokia Lumia 900 Front Camera Replacement, Reassembling Screen: passo 5, immagine 1 di 1
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
Conclusione
1Commento della guida
Is also forgot to tell about the plate between screen and battery that is glued to the battery
John Bork - Replica Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 24
Tutti i Tempi: 716
