Salta al contenuto principale
Nokia Lumia 900 Battery Replacement
Cosa ti serve
  1. Nokia Lumia 900 Battery Replacement, Opening The Phone: passo 1, immagine 1 di 2 Nokia Lumia 900 Battery Replacement, Opening The Phone: passo 1, immagine 2 di 2
    • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
    • Using the opening tool, pry the screen from the casing until they are separated from each other.
  2. Nokia Lumia 900 Battery Replacement, Remove Old Battery: passo 2, immagine 1 di 1
    • Detach connector A from the phone.
    • Use the opening tool to pry out battery from the phone.
    • The battery should come out fairly easily
  3. Nokia Lumia 900 Battery Replacement, Installing New Battery: passo 3, immagine 1 di 1
    • Place the battery in the empty battery slot
    • Attach connector A to the battery terminal.
  4. Nokia Lumia 900 Battery Replacement, Reassembling The Screen: passo 4, immagine 1 di 1
    • Slide the hinges of the left side of the screen under the left side of the plastic case
    • Clamp the right side of the screen down and make sure screen is flat
    • The screen should "click" into place
Linea Traguardo
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 3,114
