Introduzione
This guide serves the purpose of replacing the Nokia Lumia 635 camera when the user (you) cannot access the application on your phone.
Cosa ti serve
Open the back case of the phone using the plastic opening tool.
Remove the battery.
Remove the six screws shown in the photo using the torx Screwdriver 5mm.
Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
Remove the black sticker on the bottom left side (As shown in the picture).
Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
Using the plastic opening tool separate the plastic cover from the screen.
On the top left corner you will see the screens flex attached to the mother bothered, watch out when separating them.
Carefully retrieve the cameras flex as shown in the picture.
Attach the new camera’s flex to the mother board.
Altre 3 persone hanno completato questa guida.
