Salta al contenuto principale
Nokia Lumia 635 Headphone Jack Replacement
Cosa ti serve
  1. Nokia Lumia 635 Headphone Jack Replacement, Battery Removal: passo 1, immagine 1 di 2 Nokia Lumia 635 Headphone Jack Replacement, Battery Removal: passo 1, immagine 2 di 2
    • Open the back case of the phone using the plastic opening tool.
    • Remove the battery.
  2. Nokia Lumia 635 Headphone Jack Replacement, Screw Removal: passo 2, immagine 1 di 2 Nokia Lumia 635 Headphone Jack Replacement, Screw Removal: passo 2, immagine 2 di 2
    • Remove the six screws shown in the photo using the torx Screwdriver 5mm.
    • Turn your phone sideways and you will find two more screws that you will need to remove using the Torx Screwdriver 5mm.
  3. Nokia Lumia 635 Headphone Jack Replacement, Remove Hidden Screw: passo 3, immagine 1 di 2 Nokia Lumia 635 Headphone Jack Replacement, Remove Hidden Screw: passo 3, immagine 2 di 2
    • Remove the black sticker on the bottom left side (As shown in the picture).
    • Remove the screw that was under the black sticker using the Torx Screwdriver 5mm.
  4. Nokia Lumia 635 Headphone Jack Replacement, Separating Back Cover From Screen: passo 4, immagine 1 di 1
    • Using the plastic opening tool separate the plastic cover from the screen.
    • On the top left corner you will see the screens flex attached to the mother bothered, watch out when separating them.
  5. Nokia Lumia 635 Headphone Jack Replacement, Audio Jack Replacement: passo 5, immagine 1 di 1
    • Carefully retrieve the audio jack’s flex that is attached to the mother board as shown in the picture.
    • Attach the new audio jack’s flex to the mother board.
Conclusione
Altre 3 persone hanno completato questa guida.
Benjamin
Membro da: 10/07/14
173 Reputazione
1 Guida realizzata
USF Tampa, Team 7-1, Leahy Fall 2014 Membro di USF Tampa, Team 7-1, Leahy Fall 2014
USFT-LEAHY-F14S7G1
4 Membri
16 Guide realizzate
Un commento
where can you buy the headphone jack?
fERD - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 4,904
