Salta al contenuto principale
Nokia Lumia 635 630 Display Assembly Replacement with Frame
Cosa ti serve
Panoramica Video
  1. Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: passo 1, immagine 1 di 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: passo 1, immagine 2 di 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, Display Assembly with Frame: passo 1, immagine 3 di 3
    • Remove the battery and any SIM and memory cards.
    • Remove the black sticker at the bottom side of the phone.
  2. Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 2, immagine 1 di 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 2, immagine 2 di 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 2, immagine 3 di 3
    • Use a screwdriver Torx T4 and remove the 7x screws.
    • There are two other smaller screws with the same head size – remove them as well.
  3. Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 3, immagine 1 di 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 3, immagine 2 di 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame: passo 3, immagine 3 di 3
    • Lift the rear bezel and unhook the display assembly flex cable.
    • Don't use a metal tool for disconnecting the flex cable. There are many small elements near the connectors. You could break them. If you don't have a suitable tool just use your nails.
    • Now we have to transfer the earpiece.
  4. Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: passo 4, immagine 1 di 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: passo 4, immagine 2 di 3 Nokia Lumia 635 630 Display Assembly Replacement with Frame, LOUDSPEAKER: passo 4, immagine 3 di 3
    • Put the earpiece on the new display assembly and start with reassembling.
Conclusione
Altre 17 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.308 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.535 Guide realizzate
2 Commenti
Where do i get the part replacements from to replace the screen and what not?
Nathaniel Ogungbuyi - Replica
Großes Lob an Nokia, das ist noch ein super zu öffnendes Smartphone gewesen! Touchdisplay tauschen war einfach.
Tale Spinner - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 10,325
