Introduzione
Warning!
This will delete all your personal data!
If you want to keep what is stored in your SD card, remove it first!
Panoramica Video
Turn the phone off.
Press and hold the power button. When the phone vibrates, release it and press and hold the volume down button until you see the exclamation mark on the screen.
Another way to do this - press and hold the volume down button and connect the charger.
Whit the exclamation mark on the screen press this sequence of keys:
-> Volume Up
-> Volume Down
-> Power button
-> Volume Down
Altre 63 persone hanno completato questa guida.
32 Commenti
Hey, I have done it on the computer, reload the windows but still I get the exclamanition, also the battery is death right now and I don't know how its gonna charge?
Phone get rain water, I want to mention it.It opens dont problenm but that sign (!) gonna drive me mad!!
Yes if you have the numbers stored somewhere not on the phone then you just have to re add them
will my number still be there and is the phone still active, Do I need to have it reactivated??
or should i take out the sim card first??
Now would I bypass a reset protection notification
its work tnk u... : )
It worked for me....thanks a whole lot.....am happy
It does not work!!
me too it does not work! and why ?
It works.. Thanksss... :)
Thanks a million. It worked and a huge problem solved. Thanks again.
When I turn on my Lumia 630, it displays "Nokia" and goes off then comes on again and only display Nokia....will this method bring it back to normal?
Mine is the same too. I don't know what to do
It worked... thanks a bunch
It's not working, I repeated the process multiple times and I keep getting the same outcome, it just goes to the Nokia screen, and boots up the same
I have done it but still facing the same problem. The problem is that my sister has given me Nokia Lumia 635 and it is having a problem of ‘This device is locked to a specific mobile operator. Contact your mobile operator for the unlock code.
This method always had worked for me.
This method always really worked for me.
thank you very much. the method is really superb
Not work for me. Hardware reset done. anyway thanks for the details.
Wow its working
There is a sad face and the phone won't start
Phone shows a sad face and will not open
It work… Tnx
Thank you very much!
the phone loads up to a blue screen then says complete and also says below it if you'd like to know more you can search online later or this and onto of that it says 0% then error.0xc00002e3
It’s doesn’t work!
how on god’s green earth are you going to do this “to reassemble your device follow this backward” bro, it’s a Fudging factory reset, not a dissasembaly
Hallo, ich habe noch ein altes Nokia RM 974 in grün. Ich habe einen Hard-Reset durchgeführt. Nach den beiden Zahnrädern kommt aber leider nur ein ablehnendes und es resettet neu, und alles wiederholt sich. Haben Sie dafür eine Lösung?
Mine won't go to ! It keeps rebooting to Nokia
Trillix Wolfie - Replica
My phone ignores the sequence. It was set up as a child phone, and there’s no “reset phone” button in the about menu. It in fact doesn’t even have the about menu. And trying to reset it using buttons, I get exclamation mark, and once I push the Volume Up button, it starts to boot normally and ignores the rest.
Sergey Kofanov - Replica
THanks its a useful ways it works on my phone…nice one
Abasi Kadewele - Replica
thank you it worked on my phone!!! I’m very glad! Thank you again!
szabo_istvan78 - Replica
When I turn on my Lumia 635, it displays "Nokia" and goes off then comes on again and only display Nokia. After resetting it, it continues the same
Frank Inyiama - Replica
my lumia phone was switch off showing Nokia sign in every 10 seconds. after hard reset , it is showing charging sign. what to do next .
flora - Replica
Not working-B
Brandy Nickson - Replica
Thank you, it worked on my phone. I’m very happy now
Arham Jahangir - Replica
Works perfectly,
thanks.
And just a note for everyone, TAKE YOUR SD CARD OUT FIRST!!!!! IT WILL WIPE THE DATA!!!!
Austin Wilson - Replica
Worked perfectly thank you for this info!!
jessiecrego83 - Replica
non riesco a resettare il mio lumia, sarà perchè il sistema operativo è stato aggiornato con il 10?
qualcuno può suggerirmi qualcosa?
rosario marchica - Replica
