Salta al contenuto principale
Introduzione
This repair is very easy; all you need is a T5 Torx Screwdriver, and a new Digitizer Glass & Frame Assebly - it's better to order it with the Front Frame as well, as it makes repairing a lot simpler, and will give your phone a new look and feel.
  1. The first thing you'll need is a Nokia Lumia 610 with a broken front glass
    • The first thing you'll need is a Nokia Lumia 610 with a broken front glass
  2. Slide the back cover off, and remove the battery Slide the back cover off, and remove the battery
    • Slide the back cover off, and remove the battery
  3. There are 8 Torx 5 screws you have to remove, 4 on each side There are 8 Torx 5 screws you have to remove, 4 on each side
    • There are 8 Torx 5 screws you have to remove, 4 on each side
  4. After removing all 8 screws, proceed to prying off the back cover This is done very easily, by prying it from the 3 grooves depicted This step might also be done using your nails, as the clips are not strong at all
    • After removing all 8 screws, proceed to prying off the back cover
    • This is done very easily, by prying it from the 3 grooves depicted
    • This step might also be done using your nails, as the clips are not strong at all
  5. Watch out - the buttons easily fall out; just make sure you don't loose any, a'aight ?!
    • Watch out - the buttons easily fall out; just make sure you don't loose any, a'aight ?!
  6. Lift the back cover up, and pull it back - most likely, the 2 sided tape sealing the camera module will be the last thing to break loose Make sure you stick it back to the rear case assembly after this step
    • Lift the back cover up, and pull it back - most likely, the 2 sided tape sealing the camera module will be the last thing to break loose
    • Make sure you stick it back to the rear case assembly after this step
  7. Disconnect the 2 ribbon cables connecting the LCD & Digitizer to the motherboard Disconnect the 2 ribbon cables connecting the LCD & Digitizer to the motherboard Disconnect the 2 ribbon cables connecting the LCD & Digitizer to the motherboard
    • Disconnect the 2 ribbon cables connecting the LCD & Digitizer to the motherboard
  8. Now to separate the Motherboard from the front assembly !
    • Now to separate the Motherboard from the front assembly !
    • Gently pry on the 2 hooks depicted in the picture to release the motherboard
    • Again - using your nails should be just fine !
  9. Lift the motherboard up from the back, and pull it backwards Apply the same motion as with the back casing
    • Lift the motherboard up from the back, and pull it backwards
    • Apply the same motion as with the back casing
    • You should now have separated the motherboard from the LCD/Digitizer Assembly
  10. To detach the LCD, gently lift it from the sides - be careful, and don't pull too hard on the ribbon cable ! It's secured in with pretty weak double-sided tape, so this step shouldn't be a problem
    • To detach the LCD, gently lift it from the sides - be careful, and don't pull too hard on the ribbon cable !
    • It's secured in with pretty weak double-sided tape, so this step shouldn't be a problem
  11. Remove the ear-piece speaker from the Digitizer Assembly It's held in by - again - pretty weak double-sided tape
    • Remove the ear-piece speaker from the Digitizer Assembly
    • It's held in by - again - pretty weak double-sided tape
    • 2nd picture gives you a look of the front of the speaker unit - it's pretty hard to damage the membrane - though, you can never be too careful !
  12. Something very easy to forget - remove the tiny rubber gasket for the microphone, and place it in the new front panel Something very easy to forget - remove the tiny rubber gasket for the microphone, and place it in the new front panel
    • Something very easy to forget - remove the tiny rubber gasket for the microphone, and place it in the new front panel
  13. To put everything back together, just follow the same steps backward, and you should have yourself a good-as-new Nokia Lumia 610
    • To put everything back together, just follow the same steps backward, and you should have yourself a good-as-new Nokia Lumia 610
    • The last step in this guide - is trying not to break it again :)
Conclusione
Altre 6 persone hanno completato questa guida.
Darie H
Membro da: 20/11/2012
4.416 Reputazione
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 5,430
