Salta al contenuto principale
Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement
Cosa ti serve
Panoramica Video
  1. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: passo 1, immagine 1 di 2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: passo 1, immagine 2 di 2
    • Switch off the phone and remove the battery.
  2. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 2, immagine 1 di 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 2, immagine 2 di 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 2, immagine 3 di 3
    • Remove 8x Torx T5 screws.
    • With a plastic tool, start with separating the middle frame from the down side.
  3. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 3, immagine 1 di 2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 3, immagine 2 di 2
    • The Loudspeaker is on the middle frame.
    • Disconnect the LCD Display flex cable.
    • Disconnect the Touch screen flex cable.
  4. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 4, immagine 1 di 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 4, immagine 2 di 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 4, immagine 3 di 3
    • The Logic board is held by 2x locking clips at the bottom side.
    • Release it and gently remove it from the front frame.
  5. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 5, immagine 1 di 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 5, immagine 2 di 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 5, immagine 3 di 3
    • Put tape on the glass to not scatter pieces.
    • Worm the glass to melt the adhesive.
    • Use plastic tools to separate the touchscreen from the frame.
  6. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 6, immagine 1 di 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 6, immagine 2 di 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 6, immagine 3 di 3
    • After separating, clean up the sticker that remains on the borders.
    • New line.Install the new touchscreen and reassemble the device.
  7. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: passo 7, immagine 1 di 1
    • That's all.
    • Did you do it successfully?
Conclusione
Altre 4 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.182 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.519 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 1,869
