Salta al contenuto principale
Nokia Lumia 521 Battery Replacement
Cosa ti serve
  1. Nokia Lumia 521 Battery Replacement, Battery: passo 1, immagine 1 di 2 Nokia Lumia 521 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Push the plastic opening tool in between the screen and the back case of the phone.
    • Pry the top of the phone between the case and screen until they are separated.
  2. Nokia Lumia 521 Battery Replacement: passo 2, immagine 1 di 1
    • Once the cover has been removed, the battery will be visible. Grab the plastic tab and pull it to remove the battery from its place. If there is no plastic tab, use the plastic opening tool to pry the battery loose.
Conclusione
USF Tampa, Team 2-4, Sullivan Spring 2016 Membro di USF Tampa, Team 2-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G4
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 19
Tutti i Tempi: 772
