Salta al contenuto principale
Nokia Lumia 520 Battery Replacement
Cosa ti serve
  1. Nokia Lumia 520 Battery Replacement, Battery: passo 1, immagine 1 di 2 Nokia Lumia 520 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Battery Replacement: passo 2, immagine 1 di 2 Nokia Lumia 520 Battery Replacement: passo 2, immagine 2 di 2
    • Lift the spudger gently to open the back cover of the phone.
    Plastic guitar pick worked really well for me. Easy to insert and slide around to unlatch case.
    anluan - Replica
  3. Nokia Lumia 520 Battery Replacement: passo 3, immagine 1 di 2 Nokia Lumia 520 Battery Replacement: passo 3, immagine 2 di 2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 Membro di UMass Dartmouth, Team 1-5, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G5
3 Membri
8 Guide realizzate
2 Commenti
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
beerwings1776 - Replica
Greetings I have a Lumia & I need the Screen and Battery,so how can I get those 2?
Ayoba - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,540
