Salta al contenuto principale
Nokia E90 QWERTY Keyboard Replacement
Cosa ti serve
  1. Nokia E90 QWERTY Keyboard Replacement, Battery Cover and Battery: passo 1, immagine 1 di 1
    • In order to remove the back cover, you must press the indicated button.
  2. Nokia E90 QWERTY Keyboard Replacement: passo 2, immagine 1 di 2 Nokia E90 QWERTY Keyboard Replacement: passo 2, immagine 2 di 2
    • With the button pressed, apply light pressure and slide the back cover off.
    • This will allow you to access the battery
  3. Nokia E90 QWERTY Keyboard Replacement: passo 3, immagine 1 di 1
    • In order to remove the battery, pull it out from the same side that the rubber button is on.
  4. Nokia E90 QWERTY Keyboard Replacement, Back Cover: passo 4, immagine 1 di 3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: passo 4, immagine 2 di 3 Nokia E90 QWERTY Keyboard Replacement, Back Cover: passo 4, immagine 3 di 3
    • Using a plastic opening tool, separate the back cover from the phone.
  5. Nokia E90 QWERTY Keyboard Replacement: passo 5, immagine 1 di 2 Nokia E90 QWERTY Keyboard Replacement: passo 5, immagine 2 di 2
    • Continue along the edge with the plastic opening tool.
  6. Nokia E90 QWERTY Keyboard Replacement: passo 6, immagine 1 di 3 Nokia E90 QWERTY Keyboard Replacement: passo 6, immagine 2 di 3 Nokia E90 QWERTY Keyboard Replacement: passo 6, immagine 3 di 3
    • Gently, remove the back cover.
  7. Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: passo 7, immagine 1 di 3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: passo 7, immagine 2 di 3 Nokia E90 QWERTY Keyboard Replacement, QWERTY Keyboard: passo 7, immagine 3 di 3
    • Unscrew the indicated screws using the T5 screwdriver.
  8. Nokia E90 QWERTY Keyboard Replacement: passo 8, immagine 1 di 2 Nokia E90 QWERTY Keyboard Replacement: passo 8, immagine 2 di 2
    • Open the phone up and use the plastic opening tool to remove the cover to the keyboard.
    • Be careful not to break the plastic during this step; do your best not to force anything.
  9. Nokia E90 QWERTY Keyboard Replacement: passo 9, immagine 1 di 2 Nokia E90 QWERTY Keyboard Replacement: passo 9, immagine 2 di 2
    • The button board will be loose once the cover is removed.
    • Lift it up to reveal the sensor board.
  10. Nokia E90 QWERTY Keyboard Replacement: passo 10, immagine 1 di 2 Nokia E90 QWERTY Keyboard Replacement: passo 10, immagine 2 di 2
    • With the T5 Screwdriver, remove the marked screws.
  11. Nokia E90 QWERTY Keyboard Replacement: passo 11, immagine 1 di 2 Nokia E90 QWERTY Keyboard Replacement: passo 11, immagine 2 di 2
    • With the screws removed, the sensor board should be free to flip up.
  12. Nokia E90 QWERTY Keyboard Replacement: passo 12, immagine 1 di 2 Nokia E90 QWERTY Keyboard Replacement: passo 12, immagine 2 di 2
    • Disconnect the wire with the plastic opening tool.
  13. Nokia E90 QWERTY Keyboard Replacement: passo 13, immagine 1 di 3 Nokia E90 QWERTY Keyboard Replacement: passo 13, immagine 2 di 3 Nokia E90 QWERTY Keyboard Replacement: passo 13, immagine 3 di 3
    • Remove the screws marked.
    • The Screw on the left is located underneath the cable.
    • With those screws removed, the circuit board and sensor board will be detached from the rest of the phone.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 18-21, Garner Spring 2011 Membro di Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 6,358
