Salta al contenuto principale
Nokia E90 Front Cover Replacement
Cosa ti serve
  1. Nokia E90 Front Cover Replacement, Front Cover: passo 1, immagine 1 di 1
    • Start with the phone in the flipped open position.
    • You must remove the sticker in the center, below the screen to reveal the center screw.
    • Use a T5 screwdriver to remove all three screws, loosening the front screen.
  2. Nokia E90 Front Cover Replacement: passo 2, immagine 1 di 2 Nokia E90 Front Cover Replacement: passo 2, immagine 2 di 2
    • Flip the phone to the closed position and turn to the front screen.
    • The front cover will now be loose enough for you to remove by grabbing the edges and lightly pulling the cover off.
Conclusione
Cal Poly, Team 18-21, Garner Spring 2011 Membro di Cal Poly, Team 18-21, Garner Spring 2011
CPSU-GARNER-S11S18G21
3 Membri
8 Guide realizzate
2Commenti sulla guida
I have a n90 done which will not switch on. I have changed the battery and still nothing.pressing the top power button but nothing.trying to get old pics off the phone any help?
Smith - Replica
Hello Mr Smith. Have you tried to recharge the battery as it is in the phone in question? Recharge the battery while it is in the phone first, IF the phone in question still does not boot up then get another battery from ebay. I have a similar E90 as yours and the battery did go flat in the end, like all batteries, I just got a new battery and then recharged the battery while it is in the phone. Good luck.
Keith N Searle -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 38
Tutti i Tempi: 5,184
