Salta al contenuto principale
Nokia E61i Front Cover Replacement
Cosa ti serve
  1. Nokia E61i Front Cover Replacement, Battery: passo 1, immagine 1 di 2 Nokia E61i Front Cover Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Front Cover Replacement: passo 2, immagine 1 di 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Front Cover Replacement: passo 3, immagine 1 di 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Front Cover Replacement, Front Cover: passo 4, immagine 1 di 2 Nokia E61i Front Cover Replacement, Front Cover: passo 4, immagine 2 di 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Front Cover Replacement: passo 5, immagine 1 di 1
    • Remove the cover by pulling it up and off.
Conclusione
Cal Poly, Team 9-63, Walters Spring 2011 Membro di Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,882
