Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
This guide will illustrate how to remove the battery in the Nokia E61i.
Strumenti
Nessun attrezzo specificato.
  1. To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it. Now slide the back cover off of the phone.
    • To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it.
    • Now slide the back cover off of the phone.
  2. Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
    • Once the backplate is removed, look to the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Use your finger to lift the battery out.
    • Use your finger to lift the battery out.
    • The E61i uses a Nokia BP-4L standard battery.
Conclusione
Cal Poly, Team 9-63, Walters Spring 2011 Membro di Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,134
