Salta al contenuto principale
Nokia Asha 201 Screen Replacement
Cosa ti serve
  1. Nokia Asha 201 Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Remove back cover of device by pressing firmly and sliding the cover off.
  2. Nokia Asha 201 Screen Replacement: passo 2, immagine 1 di 1
    • Using your finger, lift up on battery to remove from the device.
  3. Nokia Asha 201 Screen Replacement: passo 3, immagine 1 di 1
    • Using a screwdriver, remove the two screws from the back case.
  4. Nokia Asha 201 Screen Replacement: passo 4, immagine 1 di 1
    • Pry off the front case using a iFixit opening tool.
  5. Nokia Asha 201 Screen Replacement: passo 5, immagine 1 di 1
    • Remove the Keyboard with your hands.
  6. Nokia Asha 201 Screen Replacement: passo 6, immagine 1 di 1
    • Remove the four screws pictured here.
  7. Nokia Asha 201 Screen Replacement: passo 7, immagine 1 di 1
    • Using the iFixit opening tool, separate the screen from motherboard.
    • Unplug your old screen from your phone, unpack your new one and gently plug in the new screen. Make sure you plug in the screen just like the old one was placed in the phone.
  8. Nokia Asha 201 Screen Replacement: passo 9, immagine 1 di 1
    • After plugging in the new screen put back the screen onto the motherboard.
  9. Nokia Asha 201 Screen Replacement: passo 10, immagine 1 di 1
    • Use a philips #00 screwdriver to put back the four 3.5 mm screws trays pictured here.
  10. Nokia Asha 201 Screen Replacement: passo 11, immagine 1 di 1
    • Using your fingers place the keyboard back like in the picture.
  11. Nokia Asha 201 Screen Replacement: passo 12, immagine 1 di 1
    • Using your fingers and the Phillips opening tool reposition and adjust the front case onto the phone.
  12. Nokia Asha 201 Screen Replacement: passo 13, immagine 1 di 1
    • Using the Phillips #0 screwdriver, screw back in the two screws to the back case.
  13. Nokia Asha 201 Screen Replacement: passo 14, immagine 1 di 1
    • Using your fingers put back the battery in the back of the phone properly.
  14. Nokia Asha 201 Screen Replacement: passo 15, immagine 1 di 1
    • Slide back in the phone cover to the back of the device.
Conclusione
Replacing Nokia Asha 201 screen takes several steps. These steps should be followed precisely to have the screen replaced without complications. Each step should be done before start doing the next step. After you’re done following these steps, you should start reassembling the device. To reassemble the device, follow these instructions in reverse order.
USF Tampa, Team S1-G3, Leahy Fall 2019 Membro di USF Tampa, Team S1-G3, Leahy Fall 2019
USFT-LEAHY-F19S1G3
4 Membri
5 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 39
Tutti i Tempi: 853
