Salta al contenuto principale
Nokia 8390 Charging Port Replacement
Cosa ti serve
  1. Nokia 8390 Charging Port Replacement, Back Cover: passo 1, immagine 1 di 1
    • Locate the button on the bottom of the back cover.
  2. Nokia 8390 Charging Port Replacement: passo 2, immagine 1 di 3 Nokia 8390 Charging Port Replacement: passo 2, immagine 2 di 3 Nokia 8390 Charging Port Replacement: passo 2, immagine 3 di 3
    • Depress the button with your finger.
    • While the button is depressed, slide the back cover off of the phone.
  3. Nokia 8390 Charging Port Replacement, Outer Case: passo 3, immagine 1 di 3 Nokia 8390 Charging Port Replacement, Outer Case: passo 3, immagine 2 di 3 Nokia 8390 Charging Port Replacement, Outer Case: passo 3, immagine 3 di 3
    • Grasp the top and bottom of the front cover.
    • Grasp the phone body with your other hand.
    • Lightly pull the casing off of the phone.
  4. Nokia 8390 Charging Port Replacement, Motherboard: passo 4, immagine 1 di 3 Nokia 8390 Charging Port Replacement, Motherboard: passo 4, immagine 2 di 3 Nokia 8390 Charging Port Replacement, Motherboard: passo 4, immagine 3 di 3
    • Locate the six star-shaped screws on the phone.
    • Note: There are two on the bottom end, two in the middle, and two on the top end.
    • Remove these screws using the screwdriver.
  5. Nokia 8390 Charging Port Replacement: passo 5, immagine 1 di 3 Nokia 8390 Charging Port Replacement: passo 5, immagine 2 di 3 Nokia 8390 Charging Port Replacement: passo 5, immagine 3 di 3
    • Grab the top and bottom of the phone casing.
    • Carefully pull the motherboard apart from the bottom casing.
    • The circuit board should be divided into two parts.
  6. Nokia 8390 Charging Port Replacement: passo 6, immagine 1 di 3 Nokia 8390 Charging Port Replacement: passo 6, immagine 2 di 3 Nokia 8390 Charging Port Replacement: passo 6, immagine 3 di 3
    • Grab the top and bottom of the remaining casing.
    • Carefully pull apart the casing from the circuit board.
  7. Nokia 8390 Charging Port Replacement: passo 7, immagine 1 di 1
    • The circuit board should be divided into three parts, completely separate from the back casing, as shown.
  8. Nokia 8390 Charging Port Replacement, Charging Port: passo 8, immagine 1 di 3 Nokia 8390 Charging Port Replacement, Charging Port: passo 8, immagine 2 di 3 Nokia 8390 Charging Port Replacement, Charging Port: passo 8, immagine 3 di 3
    • Hold back of phone in hand so that hand is not covering any parts.
    • Grasp charge port with thumb.
    • Pull out with hand.
Conclusione
Altre 2 persone hanno completato questa guida.
Clinton
Membro da: 10/22/12
57 Reputazione
7 Guide realizzate
Clemson, Team 14-5, Benson Fall 2012 Membro di Clemson, Team 14-5, Benson Fall 2012
CLEM-BENSON-F12S14G5
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 347
