Salta al contenuto principale
Nokia 8290 Adhesive White Film Replacement
Cosa ti serve
  1. Nokia 8290 Adhesive White Film Replacement, Front Cover: passo 1, immagine 1 di 3 Nokia 8290 Adhesive White Film Replacement, Front Cover: passo 1, immagine 2 di 3 Nokia 8290 Adhesive White Film Replacement, Front Cover: passo 1, immagine 3 di 3
    • Locate the small button on the top of the phone.
    • Depress the button.
    • With your other hand, pull the front cover away from the phone.
  2. Nokia 8290 Adhesive White Film Replacement, Circuit Board: passo 2, immagine 1 di 3 Nokia 8290 Adhesive White Film Replacement, Circuit Board: passo 2, immagine 2 di 3 Nokia 8290 Adhesive White Film Replacement, Circuit Board: passo 2, immagine 3 di 3
    • Remove all six 5.3 mm long T6 screws.
    • Remove the circuit board/faceplate sub-assembly from the back of the phone.
    • Take care to place screws in a safe location.
  3. Nokia 8290 Adhesive White Film Replacement: passo 3, immagine 1 di 3 Nokia 8290 Adhesive White Film Replacement: passo 3, immagine 2 di 3 Nokia 8290 Adhesive White Film Replacement: passo 3, immagine 3 di 3
    • Using your fingers, pull the small plastic tab away from the circuit board/faceplate sub-assembly.
    • Rotate the faceplate away from the circuit board.
    • Gently remove the faceplate from the circuit board, taking care to not break the small plastic tab on the other side of the sub-assembly.
  4. Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: passo 4, immagine 1 di 3 Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: passo 4, immagine 2 di 3 Nokia 8290 Adhesive White Film Replacement, Adhesive White Film: passo 4, immagine 3 di 3
    • Hold the faceplate with the adhesive film facing upwards.
    • Use the spudger to pry the adhesive film away. This can be done by working the tool back and forth underneath the film.
    • It is easiest to begin in the upper left corner.
  5. Nokia 8290 Adhesive White Film Replacement: passo 5, immagine 1 di 3 Nokia 8290 Adhesive White Film Replacement: passo 5, immagine 2 di 3 Nokia 8290 Adhesive White Film Replacement: passo 5, immagine 3 di 3
    • Continue to loosen the film with the spudger.
    • Once the film has been mostly loosened, you can peel away the film.
    • Once the film has been removed, the microphone may fall out, if so, place it aside until all other repairs are finished.
Conclusione
Clemson, Team 15-3, Benson Fall 2012 Membro di Clemson, Team 15-3, Benson Fall 2012
CLEM-BENSON-F12S15G3
3 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 333
