Salta al contenuto principale
Nokia 8265 Keypad Replacement
Cosa ti serve
  1. Nokia 8265 Keypad Replacement, Keypad: passo 1, immagine 1 di 1
    • Using a plastic opening tool, wedge the tip of the tool into the side of the phone's faceplate
    • To pry open, wiggle/twist the tip of the tool, until faceplate pops up.
  2. Nokia 8265 Keypad Replacement: passo 2, immagine 1 di 1
    • Once popped off, remove the faceplate entirely, exposing the keypad.
  3. Nokia 8265 Keypad Replacement: passo 3, immagine 1 di 1
    • You can pick up the keypad with ease, as it is not attached to the phone itself.
  4. Nokia 8265 Keypad Replacement: passo 4, immagine 1 di 1
    • To clean keypad if it is not functioning properly, use a cloth to wipe away any spills, or water damage
Conclusione
If cleaning off keypad does not work, insert your new keypad, and follow steps in reverse order to reassemble your device.
Jack
Membro da: 04/20/12
1 Reputazione
4 Guide realizzate
SUNY Cortland, Team 1-1, Getto Spring 2012 Membro di SUNY Cortland, Team 1-1, Getto Spring 2012
SUNYCORT-GETTO-S12S1G1
2 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 804
