Salta al contenuto principale
Nokia 8260 Antenna Replacement
Cosa ti serve
  1. Nokia 8260 Antenna Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off the cell phone.
  2. Nokia 8260 Antenna Replacement: passo 2, immagine 1 di 1
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 Antenna Replacement: passo 3, immagine 1 di 1
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 Antenna Replacement: passo 4, immagine 1 di 1
    • Remove the back cover.
  5. Nokia 8260 Antenna Replacement: passo 5, immagine 1 di 1
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 Antenna Replacement: passo 6, immagine 1 di 1
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 Antenna Replacement, Antenna: passo 7, immagine 1 di 1
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 Antenna Replacement: passo 8, immagine 1 di 1
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 Antenna Replacement: passo 9, immagine 1 di 1
    • Remove the antenna door.
  10. Nokia 8260 Antenna Replacement: passo 10, immagine 1 di 1
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
Conclusione
Aaron Jen
Membro da: 04/11/10
1 Reputazione
7 Guide realizzate
Cal Poly, Team 27-94, Amido Spring 2010 Membro di Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,243
