Salta al contenuto principale
Nokia 6590i Battery Charger Connector Replacement
Cosa ti serve
  1. Nokia 6590i Battery Charger Connector Replacement, Battery: passo 1, immagine 1 di 2 Nokia 6590i Battery Charger Connector Replacement, Battery: passo 1, immagine 2 di 2
    • Press the button on the bottom of the rear cover.
    • Keep the button pressed while pulling the cover downward to remove the back cover.
    • Lift the cover off.
  2. Nokia 6590i Battery Charger Connector Replacement: passo 2, immagine 1 di 1
    • To remove the battery, push it down from the top and pull it out.
  3. Nokia 6590i Battery Charger Connector Replacement, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: passo 3, immagine 1 di 1
    • Grip the front cover from the bottom.
  4. Nokia 6590i Battery Charger Connector Replacement: passo 4, immagine 1 di 1
    • Lift the front cover off.
  5. Nokia 6590i Battery Charger Connector Replacement: passo 5, immagine 1 di 1
    • Remove the six screws using a T6 torx screwdriver.
  6. Nokia 6590i Battery Charger Connector Replacement: passo 6, immagine 1 di 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  7. Nokia 6590i Battery Charger Connector Replacement: passo 7, immagine 1 di 1
    • Remove assembly from phone
  8. Nokia 6590i Battery Charger Connector Replacement, Logic Board: passo 8, immagine 1 di 1
    • The logic board now sits on top of the phone.
  9. Nokia 6590i Battery Charger Connector Replacement: passo 9, immagine 1 di 1
    • Lift the logic board out of the phone.
  10. Nokia 6590i Battery Charger Connector Replacement, Battery Charger Connector: passo 10, immagine 1 di 1
    • Locate battery charger connector
  11. Nokia 6590i Battery Charger Connector Replacement: passo 11, immagine 1 di 1
    • Grasp top and bottom of battery charger connector on the left side
  12. Nokia 6590i Battery Charger Connector Replacement: passo 12, immagine 1 di 1
    • Lift out the battery charger connector
Conclusione
Cal Poly, Team 22-3, Maness Fall 2010 Membro di Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,885
