Salta al contenuto principale
Nokia 6350-1b Logic board Replacement
Cosa ti serve
  1. Nokia 6350-1b Logic board Replacement, Taking off the plastic frame: passo 1, immagine 1 di 2 Nokia 6350-1b Logic board Replacement, Taking off the plastic frame: passo 1, immagine 2 di 2
    • Using a plastic pry, get between the plastic frame and the rest of the phone.
    • Move it along the frame unlocking the locks that keep the frame in place.
    • Remove the plastic frame.
    • Be careful not to pry to hard and crack the plastic frame.
  2. Nokia 6350-1b Logic board Replacement, Removing the screen cover: passo 2, immagine 1 di 3 Nokia 6350-1b Logic board Replacement, Removing the screen cover: passo 2, immagine 2 di 3 Nokia 6350-1b Logic board Replacement, Removing the screen cover: passo 2, immagine 3 di 3
    • Using a T-5 screw driver, unscrew the screws on the four corners of the phone.
    • Using a pry, get between the screen cover and the rest of the phone.
    • Move alone this layer unlocking the various locks that keep it in place.
    • Carefully remove the screen cover to reveal the logic board.
    • Keep track of the four small screws. They will be needed to put the phone back together.
  3. Nokia 6350-1b Logic board Replacement, Removing broken logic board: passo 3, immagine 1 di 3 Nokia 6350-1b Logic board Replacement, Removing broken logic board: passo 3, immagine 2 di 3 Nokia 6350-1b Logic board Replacement, Removing broken logic board: passo 3, immagine 3 di 3
    • Disconnect the flex cable from the logic board.
    • Disconnect the camera from the logic board.
    • Disconnect the LCD display screen.
    • Disconnect the LCD phone screen.
    • Carefully remove the broken logic board by freeing it from the various locks holding it in place.
    • Be careful not to touch either of the screens. You can leave finger prints and damage the screens.
  4. Nokia 6350-1b Logic board Replacement, Replacing Logic Board: passo 4, immagine 1 di 2 Nokia 6350-1b Logic board Replacement, Replacing Logic Board: passo 4, immagine 2 di 2
    • Take the new logic board and connect all the parts you just disconnected to their correct locations.
  5. Nokia 6350-1b Logic board Replacement: passo 5, immagine 1 di 2 Nokia 6350-1b Logic board Replacement: passo 5, immagine 2 di 2
    • Place the cover so that it is in the correct position to be re-installed.
    • Press gently on the cover so that it snaps back into place.
Conclusione
Adrianna
Membro da: 04/18/12
35 Reputazione
2 Guide realizzate
SUNY Cortland, Team 1-2, Getto Spring 2012 Membro di SUNY Cortland, Team 1-2, Getto Spring 2012
SUNYCORT-GETTO-S12S1G2
2 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,577
