Salta al contenuto principale
Nokia 6200 Classic SIM Card Replacement
  1. Nokia 6200 Classic SIM Card Replacement, Battery: passo 1, immagine 1 di 1
    • Turn the phone so it is face down (keypad side is down).
  2. Nokia 6200 Classic SIM Card Replacement: passo 2, immagine 1 di 3 Nokia 6200 Classic SIM Card Replacement: passo 2, immagine 2 di 3 Nokia 6200 Classic SIM Card Replacement: passo 2, immagine 3 di 3
    • Press and hold the button located at the bottom of the phone.
    • Slide the back of the phone downwards and away from the main body.
    • Remove the backing and place it to the side.
  3. Nokia 6200 Classic SIM Card Replacement: passo 3, immagine 1 di 3 Nokia 6200 Classic SIM Card Replacement: passo 3, immagine 2 di 3 Nokia 6200 Classic SIM Card Replacement: passo 3, immagine 3 di 3
    • Locate indentation from which battery can be removed.
    • Place finger in indentation and lift battery up from phone's body.
    • Remove battery from phone's body.
  4. Nokia 6200 Classic SIM Card Replacement, SIM Card: passo 4, immagine 1 di 1
    • Push the SimCard towards the bottom of the phone.
  5. Nokia 6200 Classic SIM Card Replacement: passo 5, immagine 1 di 2 Nokia 6200 Classic SIM Card Replacement: passo 5, immagine 2 di 2
    • Slide finger underneath top of SimCard.
    • Lift up the SimCard and rotate the top of the SimCard so it moves toward the bottom of the phone.
  6. Nokia 6200 Classic SIM Card Replacement: passo 6, immagine 1 di 2 Nokia 6200 Classic SIM Card Replacement: passo 6, immagine 2 di 2
    • Pull up on the SimCard and remove it from the back of the phone.
    • Place the SimCard to the side.
Conclusione
To insert a new SimCard, simply push the card in as shown in step 6, and snap it in place.
Reid Polstra
Membro da: 10/22/12
1 Reputazione
7 Guide realizzate
Clemson, Team 15-5, Benson Fall 2012 Membro di Clemson, Team 15-5, Benson Fall 2012
CLEM-BENSON-F12S15G5
3 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 789
